My Motherboard will be an Asus A7V8X-X and the cpu will be a 2500 barton. and yup that is how i got my 9700 but thx
Good stuff isn't it, worked for my 6800 Ah, sorry I forgot you mentioned that already. If you had PC3200 ram you could bump you 2500 up to a 3200 with a simple overclock. But it's no big deal.
I already have the ram and vid card so its better and yeah i still could for pc 3200 but what the hell the pc isnt for me so and yeah less then $150 and that includes shipping but i hope everything works properly
Im getting 256 mb of pc 3200 in the mail soon. right now in my pc i have a 512 of pc 3200 and a 512 of pc 2700. when i get my 256 of pc 3200 in the mail should i just loose the 512 od 2700 and only use the 512 and 256 of 3200 that i have ? it will be less then a gig but i think it will be better like that what do you guys think?
Hmmm, it would be nice to have all your ram running at the same speed and overclocking would be easier but I think performance would be very similar either way. Try and see what happens, maybe you'll be impressed with the speed. Or you could throw it all in and have an odd 1.25 gigs or ram but I wouldn't bother.
Try using different combo's first but if you're not planning on overclocking stick with what you have
well guy i found this one but i really dont know?? http://cgi.ebay.com/60-GB-Seagate-H...236239814QQcategoryZ99249QQrdZ1QQcmdZViewItem
