I want to play Star Wars Jedi Knight Jedi Academy demo, but an OpenGL error comes up. I downloaded the latest nvidia drivers for Nvidia RIVA TNT2 M64 ERROR: JA: v1.0.0.4 win-x86 Aug 29 2003 Initialising zone memory ..... ----- FS_Startup ----- Current search path: C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy Demo\GameData/base ---------------------- 0 files in pk3 files Running in restricted demo mode. ----- FS_Startup ----- Current search path: C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy Demo\GameData\demo\assets0.pk3 (5451 files) C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy Demo\GameData/demo ---------------------- 5451 files in pk3 files execing default.cfg couldn't exec jaconfig.cfg couldn't exec autoexec.cfg ...detecting CPU, found AMD w/ 3DNow! ------- Input Initialization ------- Skipping check for DirectInput Joystick is not active. ------------------------------------ ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- --- Common Initialization Complete --- Working directory: C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy Demo\GameData Initializing OpenGL subsystem ...initializing QGL succeeded ...setting mode 4: 800 600 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (800x600) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (4) ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ----- CL_Shutdown ----- ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem What do i do? I have nvidia RIVA TNT2 M64, Windows XP Profession Edition with SP2, 128 MB RAM? So what do i do????
I downloaded the latest Nvidia RIVA TNT2 M64 driver, 44.x and it says it supports OpenGL 2.x and DirectX9.0c?, after i installed that, it actually work and looked better. For instance I played Harry Potter and the Prisoner of Azkaban, with the latest RIVA TNT2 M64 driver and it worked. so why didn't it work for Star Wars Jedi Knight Jedi Academy demo???
That's hard to say. I would try to download the demo again in case you have a file that's been borked.
Well Jedi Academy is Open GL specific, where Harry Potter is Direct3D specific. These requirements make a big difference between games! You card is almost on the very bottom of the minimum system requirements for Jedi Academy so i will suprised if it even works correctly. If you've already installed the latest M64 drivers, i'd suggest re-installing the latest version of DirectX 9.0c. Other than that, i don't know what the problem could be!
