Lights Blink when power button is pressed
Discussion in 'Power Supplies and UPS's' started by MSIJohn, Jan 19, 2012.
  1. MSIJohn
    MSIJohn Geek Trainee
    Hello , I'm having a BIG problem with my computer , When i press the power button the lights blink once on my removable bay hard drives and it won't start , at all...
    I'v recorded a Video just to show you guys exactly what it's doing , It's my fathers computer , i turned it off one day and it wouldn't turn back on so i got scared lol, the power supply when it was turned on used to make a hissing sound.... heres the link http://www.youtube.com/watch?v=_T-LjX1McPo please watch and share with me any info you have! thank you so much
  2. Ghostman 1
    Change or test your power supply first, If that doesn't work then it is probably your Hard drive or motherboard..
  3. MSIJohn
    it isn't the hard drive bud , how do i test the power supply ?
  4. Ghostman 1
    You need to try another power supply to see if that is your problem, OR try your power supply into another pc..
  5. MSIJohn
    i was playing around and i decided to spam the power button, then the lights flickerd faster and faster, then in started! then it cut off and restarted its self, i smelt abit of smoke so i switched it off, i tried to fire it back up but now the lights flicker very fast!..... could it be the switch or the power pack , it aint the motherboard as it all started right ?
  6. Ghostman 1
    Smell the back of the computer where the power supply is, check for electrical smell.. If so the power supply is burnt..
