Hi you all: I recently bought an ASUS Deluxe with nForce2 chipset. Pretty expensive Mobo by the way. :blink: Anyhow, I bought along with it a 512 MB memory stick with 400 Mhz. My problem is that no matter what changes I make in the BIOS, I cannot get the Memory to run at 400 Mhz. :crash: And the Mobo says it's 400 Mhz System Bus ready! Please, I would really appreciate it if someone would help me solve this. It's been two weeks now and I'm really frustrated. Well, thanks in advance for your help. Specs. ASUS Deluxe Nvidia nForce2 AMD Athlon 2600 XP 512 MB RAM 60 GB Maxtor 400 W PSU Nvidia FX 5600 (256RAM) Sound Blaster 5.1 Win 2000
Is the memory currently running at 333MHz? Does this help at all? Note: It's reportedly very bad form to answer a question with a question, you know
under the advanced chipset features menu, there should be an option called "cpu interace". Set it to aggressive. Then change the memory frequency to 120% (which is the ratio of 200/166) and your memory should run at 200mhz. However, you will gain performance in running the memory in sync with the bus speed, so Isuggst you select "sync" instead of 120%. I know it sounds odd, but if your cpu bus is at 166, your system will be faster with the memory at 166 rather than at 200. That's on a AMD setup. Intel is different. (...is costly and has enough money....buy AMD )
Wow, you guys really know your stuff! :agree: I had already gone to advanced chipset, and adjust the settings to agressive, but it gave me a lot of problems. It seems that when you set it to "agressive" the Mobo overclocks itself or something. I'll try both of your suggestions anyways and tomorrow I'll let you know how it went. Thanks again.
I know I said I would tell you how it went, but I didn't have the time today. I'll try both of your suggestions on the weekend and report the results on Monday. :read:
Ok. Turns out that you were both right. The frequency of the memory is directly related to the FSB of the processor. That's my problem. Guess I won't be running my MEM at 400 Mhz until I change my CPU. Anyways, thanks for your help guys!
You're welcome BTW, try not to be too dissapointed about running at 333MHz. You'll find that (memory benchmarks aside) you actually get better overall performance when the FSB and RAM are matched clock for clock.
