My cd rom drive
Discussion in 'Storage Devices' started by jcoxy4, Aug 3, 2006.
  1. donkey42
    donkey42 plank
    set all IDE devices to C/SEL and connect HDD to the end of the primary channels IDE cable, then connect CD to any IDE connector, and 4 pin molex connector (power) then enter the BIOS and auto detect HDD's the save to CMOS and exit, now everything should be ok
  2. jcoxy4
    jcoxy4 Geek Trainee
    hi,
    the ide cables i am using do not have two ide connections.they are both simple ide cables with one connection to the motherboard and one connection to the hard drive.Then a seperate ide cable attatches the cd rom drive to the motherboard.does this mean they are both set as master.
    All help appreciated ..
    regards,
    james
  3. donkey42
    donkey42 plank
    not nesisarily, each 1 could be set to master, slave or C/SEL
    you need to check the location of the small jumper (probably next to the IDE connector) then look for a label or diagram on the HDD, the CD drive will either have a label or have a letter stamped into the metal next to the jumper
    • M = Master
    • S = Slave
    • CS = C/SEL
    put the jumper in the correct position, taking care to notice the orientation (usually part of IDE connector is visible on label)
