Hi all, I've got an IBM Kiosk PC here that is running Win2K. The PC is not supported by anyone & it runs a touch screen application for patients to announce their arrival at the surgery. The process is not exactly taxing. However, there is a problem related to the roaming profiles installed by our clinical system provider. When the PC boots a registry error message is shown. If I try to run regedit to investigate & correct this error, regedit starts to run then quitely unloads itself. I want to do a repair so I can take things further but can't find a W2K CD to do this. Anyone know if I can do a repair with out a CD or if not where I might get a CD from? TIA.
I don't think it is possible to do a repair without a CD. As far as getting a CD is concerned...If you have enough memory... minimum 512 preferably 1 GB an XP OS will work. But before you go that route you might be better off getting a new machine. What are the specs on this unit?
