randomfever
Geek
Alright. Yeah, I'm sort of in the middle of choosing these two, 7950gt and 8800. =/
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I wouldn't recommend that move.
In the short term you may see this as cheaper, but in the future (a year or so, maybe less) you might want to play Crysis and CoD4 and not be able to run them too well. This means you will then buy a DX10 card, which may be less than the DX10 card, but if you had just bought the DX10 card in the first place you wouldn't need an upgrade anyway! :D
Basically leave the Multiplier at 9, make your bus speed 400 and make your cpu voltage 1.212-1.215 volts and you should be set. All of these are accessible in you BIOS, probably under advanced or something to that effect. Look up your motherboard and you may find a "virtual BIOS" on the gigabyte website.
That should make your proc 3gigs I believe. You will no longer be bottlenecked by multiple applications as long as you don't overdo it.
